1 - 2 of 2 Posts
My urge to get a new toy has prevailed so before that can happen...
This is a White 2013 Suzuki Burgman 650 ABS with just over 25400 miles. I will be continuing to ride so miles will likely be a little higher. I bought it in 2018 with 3301 miles.
It has the following standard features:
-ABS front and rear brakes
-Electrically adjusting windscreen
-Electrically retracting mirrors
-50 Liter under seat storage box
-2 small glove boxes in dash along with one large locking glove box
-12 vdc socket in large glove box
-Parking brake lever on side just below nose of seat
-Adjustable front and rear brake levers
This Super Scooter also has the following added features:
-Corbin seat with covered slot for removable driver backrest (backrest not included but can be added)
-Upgraded seat lift strut with 40 lbs lift force
-Eastern Beaver 3CS 3 position auxiliary fuse block
-Stebel air horn
-90 degree CNC Aluminum valve stems
-Suzuki branded aluminum rear top case mounting plate
-Suzuki branded 46 Liter top case (actually the Kappa K49N with Suzuki badging)
-Rear LED running light bar with flashing brake light mounted under the top case mounting plate
-RAM ball mounted on top center of dash hood
-SAE pigtail connector with inline fuse for BatteryTender
-Hella H4P50TB +50 headlight bulbs for 50% more lighting distance (original bulbs still good and included)
-Bungee cord studs added to bottom of pillion grab rails (2 on each rail)
-Official Suzuki service manual is included along with added electrical diagrams for what I have installed
This Burgman is in great condition. I currently have a Shinko SR567 front bias ply tire and the OEM Bridgestone TH01 rear radial tire. This combination has been working really great together. It is the same kind of matchup as used on racing bikes (bias front with radial rear). I find my Burgman rides the curves like it is on a rail. I did drop it once from a standstill and that resulted in a slight scrape on the fairing and a broken front brake lever tip. The brake lever was replaced with new. When I bought it there was a crack in the lower leg shield under the right foot board which was completely repaired. I just recently replaced the joint headlight connector with a sealed weatherproof connector. Overall the condition is excellent. During my ownership I have regularly achieved from 58-62 mpg for all riding speeds during the summer riding season.
Added farkles have detailed documentation posted on the BurgmanUSA.com forum.
The Corbin seat is hands down THE MOST COMFORTABLE seat to ride distance on IMO. I would recommend anyone to consider getting a Corbin seat for any bike they ride. I can sit on this seat all day and still be comfortable when I arrive at the destination as when I left home. It has no rips or tears in it and is in near perfect condition. There was one thread loop that looked like it was about to wear through so I sealed it with E6000 sealer to prevent any possible damage to the seat.
All maintenance has been regularly completed and I have a chart showing dates and mileage for all maintenance performed. There is about 4000 miles on the rear tire and I have a new Bridgestone TH01 tire on hand to be put on when needed. If this sells before I replace the rear tire I am willing to ship the tire to the buyer's address in the case of a Fly-n-Ride. New rear wheel bearings were put on at the last tire change. Not really needed but did so just to be sure. I replaced the battery in May 2021. Front brake pads were replaced in May 2021. Rear brake pads and pad pins were replaced in June 2020. Otherwise all maintenance has simply been oil changes and filter changes.
Pictures show a USB-C phone power cord along the inside top of the dash hood that I will be keeping since it is specific to my cell phone.
$5800. Clean title in hand.
I am able to pick up at the airport for those who wish to Fly-n-Ride.
Suzuki 2013 Burgman 650 ABS pictures (PM me if you have trouble seeing the photo album)
And a few pics just because:
Tire Wheel Vehicle Automotive lighting Automotive tire
Tire Wheel Vehicle Automotive tire Automotive lighting
Tire Wheel Fuel tank Plant Vehicle
Automotive lighting Automotive tire Hood Motor vehicle Synthetic rubber
Speedometer Motor vehicle Plant Gauge Vehicle
Automotive lighting Light Hood Motor vehicle Bicycles--Equipment and supplies
1 - 2 of 2 Posts
