Finally got around to adding some bar mounted mirrors since the stock mirrors (even with my added blind spot mirrors) just weren't cutting it. I kept feeling uncomfortable not knowing what was happening around me.
You can find these or similar online at eBay or Amazon. I was scrolling through all kinds of mirrors that fit Honda's on eBay and stumbled across these.
Got some EMGO Honda OEM replacement mirrors for a CB1000R. Here the plastic covers that slide over the mounting screws are raised as I was adjusting them during my ride, stopping to adjust with a wrench, then road testing some more. I was real picky when searching for mirrors because many of the cool looking ones have too long aluminum arms that would place the mirrors way over the ends of the bars plus they probably vibrate more.
The stock Honda type mirrors come on short steel arms, have the mounts that screw into the existing mirror mounting holes on your lever mounts and they have the locking nut on the metal arms that screw into the mounts. That small detail is important since it lets you rotate the mirror arm where you want it then you can lock it into place with the locking nut. These things always confuse me since the arm and locking nuts are reverse threaded.
These don't look too bad since their shape sort of mimics the shape of the fairing mounted mirrors. The CB1000R is that "naked" that Honda builds in Italy so it has those different Euro-shapes for various components, versus the simpler more rounded mirrors for the new CB500 series which I also have since I used them on my previous CB1100.
Here's the part numbers if you're interested along with those two black screws that cover the mirror mounting holes on the lever mounts. They're nylon so just unscrew them, no need to be careful. At first I thought they were aluminum so I cautiously used a piece of aluminum to loosen them, doh.
Aloha,
Huladog
Aloha,
Huladog
