These instructions are part of another thread that's getting pretty lengthy so it's time to give it it's own identity.
If you are looking to run your own aftermarket lights to save money from what the dealer charges, Here are the instructions:
Watch the youtube video link.
https://www.youtube.com/watch?v=55Pj7stmYY4&list=UUhu59qgjc_cA-rgXTpqXwzw
You follow the plastic wiring casing from your HI/LOW controls down to somewhere around the top of your triple tree. Slice into the casing and the blue/white wire will be the low beam hot wire. The solid blue wire is for the high beam. Run your fog light wire up to the blue wire and tie into the hot (+) wire. There is a threaded frame hole in that area and that can be used for the ground. You can tie the ground wire (-) anywhere you want to the frame.
If you live in a state that requires a relay to keep more than 4 lights from coming on at one time. follow the schematic.
IMPORTANT: LED fog lights are highly recommended to keep the amps draw to a minimum.
Picture of my fog lights attached
If you are bored and want to see the original post, click below.
http://www.ctx1300forum.com/forum/appearance-body/7305-highway-pegs-fog-lights-together.html
