After 10 years honing its skills in a back office at Honda HQ the Valkyrie is back and with a weaponized 1832cc liquid-cooled horizontally opposed six-cylinder engine, stripped to its essentials for a curb weight of 750 pounds.
2014 HONDA VALKYRIE SPECIFICATIONS
Engine Type: 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke: 74mm x 71mm
Compression ratio: 9.8:1
Valve Train: SOHC; two valves per cylinder
Induction: PGM-FI
Ignition: Computer-controlled digital with 3-D mapping
Transmission: Five-speed
Final Drive: Shaft
Suspension
Front: 45mm cartridge fork; TBD inches travel
Rear: Pro-Arm single side swingarm with Pro-Link rear single shock with hydraulic spring preload; TBD inches travel
Brakes
Front: Dual 310mm front discs
Rear: Single 316mm rear disc
Optional ABS
Tires
Front: 130/60R-19
Rear: 180/55R-17
Wheelbase: 67.2 inches
Rake (Caster angle): 29° 50’
Trial: 114mm (4.5 inches)
Seat Height: 28.8 inches
Fuel Capacity: 6.1 gallons
Estimated Fuel Economy**: TBD
Colors: Black, Dark Red Metallic, Blue Metallic
Curb Weight*: 750 pounds (Valkyrie) / 754 pounds (Valkyrie ABS)
Induction: PGM-FI
Final Drive: Shaft
Suspension
Brakes
Optional ABS
Tires
Front: 130/60R-19
Rear: 180/55R-17
