1 - 17 of 17 Posts
Not so long ago (July 2021) I purchased and installed one of these:
and the install:
I rode 8000 miles in July for nearly a month - no problems. I parked the bike for most of August, but started it w few times.
At some point I attached my trusty battery tender:
Recently I have gone out to the bike for a ride, and I disconnect the tender and the bike turns on, but won't start, not enough cranking juice. Odd the battery tender was on it. I jump start the bike from my truck, and ride the day, no problems with several stops and starts.
Park bike - attempt to start bike the next day - weak start (no tender used because damn I just rode it less than 24 hours ago).
I did read this
but I am not sure it applies because 24 hours seems quick even for a parasite electrical draw.
so bad battery? bad battery tender?
time to buy something new?
Discussion Starter · #2 · (Edited)
so the saga continues.
I got me another battery charger:
No change in behavior. Charge the battery and it is slow / weak to start.
Ride the bike all day, do stops, and each time it starts right up.
So what's up?
The battery I bought is:
Besides the dimension differences, today I noticed:
12V 14AH - 200CCA
the battery they suggest from the selection wizard
12V 10AH - 220CCA
The factory battery: YTZ14S battery with 210 CCA
10 CCA can't be what the problem is.. can it?
I see the recent post here:
that points to a battery : YTZ14S - 12V 11.2AH 230 CCA
Have you done any meter checks to see what resting voltage is after a charge cycle. That is pull charger and put a meter on it an hour later. Start bike and turn off a couple times, what is voltage 5 mins later.
Check voltage on bike running to see what charge the alternator is putting out.
My guess bad battery the way it sounds like a charge isn't putting a strong charge on it.
so about 50 minutes later, I go out and the battery charger thinks the battery is charged
13.0 V
disconnect charger; 13.0 V
key on ; 12V
attempt start 11.5 V no start and the strong smell of ozone.
yeah I think the battery is wounded. I guess I'll take it out and get it tested at the local auto parts store.
Curious you have anything connected directly to battery? It only takes a single kill of battery to do damage. If not warranty battery and be sure to check alternator on the new one to be sure it's working good.
2014 Honda CTX1300
I agree, sounds like a bad cell.
Discussion Starter · #12 ·
Then you have a clear warranty without guilt. Should be free replacement at that age, I would start a claim. Let us know how warranty goes.
Well the battery tested "bad" at O'Reilly's - and they kindly provided a print out.
I sent a photo of that bad report to bigtimebattery.com and they quickly sent out a replacement. No fuss. It arrived in 3 days I think.
Installed new battery this morning, and I will ride a bit today. We shall see what tomorrow brings.
Discussion Starter · #14 ·
Well another day and another successful start. So I think all is ok in the world. More riding tonight and this weekend, but I think this oddity is resolved. Thanks to those who chimed in on troubleshooting and suggestions.
If you have doubts on something putting draw on battery test with a meter. Test battery with no connections after removing cables and letting sit 30 minutes or longer. Connect main cables and test...then next part.. doesn't take much to drop a battery
1 - 17 of 17 Posts
