I think I have a new one in the broken plastic department. I replaced my air cleaner this morning and everything was going smooth taking all the plastic off. I took my time and got to the air cleaner in an hour and half. I had done it myself 24K ago, so knew to take it slow, but one of the catches on the middle cowl that grab the headlight cracked (not off, just flappy). Out came the JB Weld. I was putting the top shelter back on and this time the gas door cable release was not cooperating but after about 15 minutes I finally got it on with all the parts and spring in the right places. I was fitting the top and and pushing down on the rear to seat it, and SNAP! Arrrrg. It was the molded-in plastic tab with a cut out to hold the door cable. Luckily there was enough plastic left on the tab, so I fabricated a tab out of metal and JB welded it to the plastic. I put in a small screw for extra hold. I'll let it cure over night and put it all back together in the morning. I am confident it will hold.
photos.app.goo.gl
My other options were to get a new top shelter $$ or do away with the key opener for the gas door and figure some other way of keeping the door closed while at speed.
