1 - 1 of 1 Posts
Supporting Vendors
The Bosch brand needs no introduction. Robert Bosch has opened his Workshop for Precision Mechanics and Electrical Engineering in 1886 in Stuttgart, Germany, and today the company is the world's leading supplier in several areas, including automotive, industrial, and building technologies, as well as consumer goods. Bosch’s North America-based automotive division is focused on providing top-grade precision OE components, including high-quality spark plugs.
You can choose between Platinum, Double-Platinum, and Iridium spark plugs designed and manufactured by Bosch. The difference is in the firing pin material. But regardless of that, all these spark plugs are designed to meet the same high-quality standards as original equipment and improve the performance of gasoline engines. They enhance combustion characteristics and ensure long service life. Made using the heat-shrink assembly process, Bosch spark plugs show greater resilience to extreme temperatures. All these spark plugs have large copper core center electrodes, which improves heat transfer.
Bosch® - FineWire™ Double Platinum Spark Plug
Specifications:
Thread Diameter: 14mm
Thread Pitch: 1.25mm
Seat Type: Gasket
Reach: 19mm (3/4")
Hex Size: 5/8" (16mm)
Terminal Type: Solid
Gap: .039" (1.0mm)
Center Electrode
Material: Platinum
Type: Fine Wire
Projection: Projected
Ground Electrode
Type: Standard
Quantity: 1
Resistor: Yes
Resistor Value: 6K Ohm
Heat Range: 8
Torque Specs: Cast Iron: 15-29 lb. ft. Aluminum: 15-22 lb. ft.
Electrode Material: Platinum
Insulator Type: Projected
Nominal Gap: 1 mm
Heat Range: 5
Features:
• OE specific design
• 360-degree continuous laser welded platinum tip for durability and long life
• Fine wire design delivers improved ignitability and performance life
• Copper core ground electrode for broader heat range to resist pre-ignition
• Tapered shape reduces flame shrouding for improved combustion
• Yttrium enhanced to resist wear
• Nickel-plated shell with rolled threads for complete anti-freeze and corrosion protection
• Ribbed insulator design prevents misfires due to flash-over
• Sold in packs of one
Bosch® - FineWire™ Iridium Spark Plug
Specifications:
Thread Diameter: 12mm
Seat Type: Gasket
Reach: 26.5mm (1.04")
Hex Size: 9/16" (14mm)
Gap: .024" (0.6mm)
Center Electrode
Material: Iridium
Type: Fine Wire
Ground Electrode
Type: Standard
Quantity: 1
Resistor: Yes
Heat Range: 6
Torque Specs: Cast Iron: 11-18 lb. ft. Aluminum: 11-15 lb. ft.
Electrode Material: Iridium
Nominal Gap: 1 mm
Features:
• Bosch original equipment design, materials and processes represent advanced OE technology
• Iridium center electrode tip
• Pre-gapped - no need to gap, providing faster installation
Bosch® 8114 - Double Platinum™ Spark Plug
Specifications:
Approximate Resistor Value: 6000
Center Electrode Tip Material: Platinum
Gap Size: 1.1
Product Length: 3.287402 in
Product Width: 0.712598 in
Reach: 25
Features:
• Designed to meet or exceed OE specifications
• Match the fit, form, and function of the OE design
• 100% tested
• Perfect fit guarantee
Click on the image to enter the product page at MOTORCYCLEiD.com.
To browse the full catalog of Bosh products, click the "Shop Now" button below:
Or use this link
Give our sales team a call at 888.903.4344 (Toll-Free) or 1.732.867.9995 (International) and we'll answer all your questions.​
1 - 1 of 1 Posts
