1 - 10 of 10 Posts
I use the Pro Honda Spray Cleaner & Polish. But do an online search on "motorcycle spray cleaner" and you'll see a whole lotta options from Pledge to WD40 and everything in between for plastic panel cleaners.
The ONLY problem I have with the Honda spray is availability. Seems the local hot rod buffs buy it up.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Mcguires Detailer spray and a Microfiber cloth. State Police Bikes are wiped down several times a day, most of the Motor Cops use it.
The Honda uses a Basecoat, Topcoat paint. The topcoat is Red/Clear with the Metalic in it.
I use Hondaline. It's good stuff and not pricy. $7 at my local Honda dealer. As for chips I go to Sephora. I discovered you can get a better match cheaper than using Colorbrite. $14 compared to $50. $100 if you have the red. Need 2 colors.
1+ on the Honda pro , ive been using it for years and when I traded my other bike in it still looked like new , use it on everything from paint to plastic.. one can last me a season..
I use Mcguires Detailer spray and a microfiber cloth as well.
1 - 10 of 10 Posts
