1 - 20 of 31 Posts
CTX Deluxe, red, tall wind screen, rider backrest, cruise, Garmin Zumo 396 GPS
Friends, I am considering a real "cruze control" for my CTX from au, it is worth it?
Is there anything that I should know before I buy?
Any regrets?
Any difference in mileage?
Thanks in advance
Glen
Do some searching in this forum for past discussions on this topic.
Search MCCruise, cruise control, etc.
You will find Q&A that will cover questions and concerns you will have.
I have the MCCruise and thought it a bit expensive until I realized how well made and how well designed it is for the CTX. It's not exactly some one size fits all design.
And it's very responsive, holding the set speed without any lag in throttle to keep set speed approaching inclines.
Worth every penny in my opinion.
(Edit) I noticed you may have the CTX without ABS/TC. I'm going by wheel and foot peg panel colors.
This will be handy:
This will be handy:
Awesome! Thanks Gregory
...I noticed you may have the CTX without ABS/TC. I'm going by wheel and foot peg panel colors.
I believe the wheel and foot peg panel colors are only a US thing. The rest of the world gets all the "deluxe" goodies, and some, standard. Dont know if you can get blacked out wheels etc outside of the US.
I have a deluxe (Canadian edition)
Of the CTX's I've seen here wheel colours are all grey and bikes are all deluxe. So it sounds like I need one of these Cruze controls. It's disappointing that Honda didn't include CC, it's been around for some time.
Yeah, I wasn't sure about that myself. The blacked out looks nice and it would have been great if there was a buyers choice to have either.
I like the colors of the new Goldwing but wish the same color was available for the tour model.
CTX 1300 Deluxe
Well, I decided to pull the trigger on the McCruise. Need to change out my air filter this winter anyway, so I thought I’d just take off a few more pieces and keep goin’!
They are also offering a new slim vertical switch that mounts around the handlebar next to the handgrip rather than above clutch reservoir, so less fiddlin’ with any grinding and it should look less conspicuous as well.
Not looking forward to ALL of the teardown, but know the pleasure to come during riding season will be worth it. Now I gotta order the thing.
You don't need to grind out the clutch bracket. Just wrap a thin piece of plastic around the handlebar. It gives you the extra thickness to create a gap in the clutch bracket for the control bracket to fit. And it still tightens down properly.
CTX 1300 Deluxe
Thanks Greg. I did see your other post about this to avoid grinding, so thanks for clarifying for me and others here.
I think I’m gonna go with the new slim vertical unit as it just seems a little more inconspicuous and maybe a little easier to reach? I’ve set on the bike with my left hand on the grip and tried to emulate my thumb reaching the two potential control locations, but won’t be able to fully tell until it’s on the bike.
I find myself lifting my hand from the grip most of the time to push the buttons. I thought about the ring style controller, but I plan to use that space for a mounting clamp.
CTX 1300 Deluxe
After several emails with Frank from McCruise, I discovered the new slim switch won’t fit without a modification of some type due to the mounting space required and the handlebar diameter change that occurs on the CTX’s setup. I was still considering it, but after setting on the bike to simulate the new switch locations and needed mods, I just decided to go with the new standard switch they offer as it actually seems it will be a little easier to reach and I don’t have to mess with additional mods.
Discussion Starter · #13 ·
I received my CMCruze last week. Only one week from Australia to Alberta Canada via Australia-post.... NOT UPS
UPS would charge $300 for brokerage fee. I paid $70 to customs Canada :)
Will start installing mine next week then have to wait 2-3 months to try it out:(
Same as "Papa John" not looking forward to the tear-down but the end result should be worth it :)
CTX 1300 Deluxe
Hey! Good luck with the installation Glen. I just started my first day of it today. Just going slow and taking my time and NOT pulling too hard on any piece, but gently working it out. Kind of fun actually to see the engineering behind how all the pieces fit.
I’m in no rush, but I will post when I’m finished noting how it went or any thoughts.
CTX 1300 Deluxe
So I’m quite a ways through the cruise install. When I pulled the center cowl off, I discover that neither of the two rear mounting holes had pushpins in them. I’ve read lots of opinions about replacing pushpins as they weaken, so I went searching for these in particular and noticed they were a different part number than others so I assume they may be wider or longer? But they are like $5 a piece! I don’t need them that bad cuz they weren’t there in the first place.
Do any of you have a place you get either generic or replacement pushpins at a lower price? I’m thinking they are prob used in a multitude of applications? But I’m guessing they can differ in length or shaft size so it’s hard to know the exact size you may need.
If it's this one, you can get 100 pcs for $6 on ebay
Black Font Hat Rectangle Auto part
If it's the one on the side under the seat cushion with the center that pulls out, you should find them pretty cheap on eBay too. Do a search for 6mm push pin for the pick above.
Or search for "bumper clip" for the other one.
CTX 1300 Deluxe
If it's this one, you can get 100 pcs for $6 on ebay View attachment 48552
Well Greg. You certainly win the helpful award. I found both, but before I purchase, do you know if the bumper clip would also be the 6mm size?
1 - 20 of 31 Posts
