Been doing some thinking (usually dangerous - and expensive!) about our exhaust systems. Nothing available for us to date - or probably ever.
First off - our bikes only have O2 sensors in front of the catalytic converter, correct? Located in that collector area at front of cat. where the two pipes enter? So - how does the system even know if a cat. conv. is present - since the sensor is in front?
Also - has anyone run their bike with cat. conv. installed, but not through the tailpipe? Wondering what that sounds like. . .
As far as I know, Costa71 is about the only one to modify the exhaust. From what I can tell, he left the cats. and installed a “S”-bend onto the cat. outlets to bring the outlets farther forward to mate with the Harley muffler inlets. Works, but result was a longer, heavier muffler on the stock exhaust system.
What I am wanting to do is get rid of that mess of converters in front of the rear tire - for looks and for weight-savings. Now - here’s where my thinking gets a little scattered. Why not cut the pipes where they make the final sharp bend heading into the converter, and send them straight back-and-up toward the tailpipe - like it “looks” like they do, anyway? “But what about the converters”, you may ask? Well, was thinking they could be replaced with four individual 35mm I.D. converters, welded into newly-installed pipes under the wedge-shaped chrome between downpipes and tailpipes. Would use these: https://www.ebay.com/itm/Motorcycle...503832?hash=item520bdf5498:g:u2YAAOSw~jpbLQNE. Would need to affix a bung pre-cat. on one pipe each side for the O2 sensors. Then, cut the cone-shaped front of the actual “muffler” off to facilitate running two pipes straight out the current outlets. Am thinking the new individual cats. will kill enough sound to not need an actual muffler. -OR- can dump the two pipes into the front of the current “muffler”, seal up the current inlet, and let the sound bounce around in there before exiting the current twin outlets each side.
Am just bouncing ideas off some other members here. No matter what gets done, it’s gonna be expensive. Am thinking that if the four small cats. are there, they’ll create enough back pressure to not mess things up computer-wise on the A/F mixture. Also, want it louder, but not HD obnoxiously loud. Rather liked the sound of my ‘98 Magna with baffles removed and larger outlets installed.
So - let’s kick this can around for a bit and see where it ends up!
