Well ... I’m looking at a pretty-good-shaped used right side header assembly that I just received. Has a scrape and small dent on lower side of front pipe. But I only have $55 invested - including shipping.
Have pretty much decided to keep the “muffler” 100% stock, and not insert the new single head pipe tube into the nose of it, as was my original plan. Thinking now that I will use a 2-into-1 merge collector, delete the cat conv, install an O2 sensor bung onto the collector, and have the new outlet insert into the current stock muffler inlet. (You know - that goofy-foot-looking 90* pipe on the back side of the “muffler”, entering at about the midpoint.) Have looked up parts for what I am wanting to do, but gonna wait until I can show it and explain it to a friend who is quite the master at welding, and see what he thinks.
What I have come up with is all from Cone Engineering (coneeng.com).
Looking at 304 stainless parts. The 2-into-1 collectors are
#CL2-11315-SS , 18ga. The collector inlets are for 1.125” OD headpipes, and the single outlet is 1.5” OD. Will also buy a 2’ joint of 1.75” OD 16ga stainless tubing,
#TU-ST16SS-1750 . This tubing is 1.620” ID, so thinking I can either crush this down a smidge or expand the collector a smidge to get them to slip fit rather snugly before welding. If I get angles right, should be able to get away with only one small bend per side. Want to get a ‘professional’ opinion first, as the collectors are $32.07 (x2), and the tubing is $27.95. Think this price includes ground shipping, but need to verify.
The other thing I am working on is a fixture or jig to hold the twin pipes in place once they are cut off the converter. Have already fashioned a flat plate and bolted the header flanges to it, so that end is good. Now just need to make something to ensure new outlet is at the correct angle, height, and plane as the old converter outlet, so the “mufflers” will still sit level.
If all goes as I have planned now, everything should ‘look’ 100% stock, but with a (hopefully!) throatier tone. And the computer should be a non-issue. O2 sensor will be at the collection point again, and I will make sure it is vertically in the exhaust stream about the same depth as stock.
Thinking I will get this first one made, get it installed, and see how it goes (sound- and computer-wise) before getting the other side. So ... stay tuned!
