1 - 3 of 3 Posts
I had a dead battery for 3 weeks. When I replaced the battery my ctx will not start. I have noticed the the fuel pump does not turn on. I bought another one and it still doesn't work. I have replaced the fuses and switched the relays and no luck anyone else have anything like this or other ideas to help. Thank you in advance.
My only thought is - there is a “tip sensor” that is supposed to kill the fuel pump if the bike is laid over. Saw a thread about this a couple months ago. Could be that part has failed.
Just thinkin’ our loud ...
Edit: it’s called a bank angle sensor. Search the forum for discussion. Good luck.
Discussion Starter #3
Possible I have yet to check that. But I did how ever find a 65 amp fuse blown on block B
1 - 3 of 3 Posts
