1 - 17 of 17 Posts
The problem has been discussed in many threads but I haven't seen a solution.
Problem: Gas smell after riding for an extended time or when temperature is high. I'm sorry but this problem is unacceptable. I have ridden for 46 years and owned many bikes. This is the only bike (which I intensely love) where this happens. I am confidant the had Honda continued the CTX1300 this problem would have been resolved.
The problem as I see it is that the vapors need to be "re-routed" from under the tank/seat and to rear where it can't be smelled. Or trap them and send them to the intake manifold??
So the question is: Has anyone come up with a solution?
I noticed this smell on both of my ST1100s and both CTX1300s. It's far less frequent on the CTXs than on the STs. I just always assumed it was exhaust fumes rolling back around. There have been times when I've had to change my clothes after a ride because the smell stuck to them.
There has to be a system to release pressure from the fuel tank. Maybe that dumps the vapors onto the rider.
I suspect that the fuel smell is caused from vapor being released (when pressurized) from the gas cap/tank area. A rider on the CTX700 forum (where the 700 has the same issue) claims that replacing the gas cap solved the problem. I will try that (at $50 from Honda). As an alternative, I am trying to design some kind of "pull" system to exhaust the fumes towards the rear tire. A small 12V fan comes to mind until I realized that ANY spark would ignite the fumes. Not Good!!
This gas cap looks pretty standard like a car. Why not try one similar from a car before you spend so much on Honda. You could get one from Walmart.
Discussion Starter · #10 ·
Wish I saw this, this morning... I just ordered one from Honda. I know that Honda has a company manufacture the caps for them but I couldn't find who. I imagine that Slant must have one that fits but again, knowing which one is the problem.
Greg does the cap from a 98 Dodge Ram fit tight? No problem with "screwing" it on?
Fits just fine. Comparing the two, the dimensions are the same. I want to guess it may be some sort of standard for gas caps.
Do you have a car with a similar cap? Can you cancel the Honda order?
Discussion Starter · #14 ·
Well, I just tried my 2020 Nissan Frontier gas cap and it fits! I guess there is a standard of some kind.
Discussion Starter · #15 ·
It turns out that Stant has a universal gas cap which looks like it will fit. Amazon has them for $10. Also found diesel universal caps with same dianeter and thread - only green!
The next question is... do these caps seal at the same psi that the CTX requires? Besides cornering the market on gas caps, I will find the one that works to eliminate the fuel smell. 🥸
I didn't see a valve in the CTX cap, but I did on my Dodge.
Discussion Starter · #17 ·
Got my new gas cap. Will test extensively with a ride to Texas (from NY) at end of April. Should be sufficient to finally put the cause to rest. I sure hope that is the source of the fuel vapors!
1 - 17 of 17 Posts
