No power anywhere, or just no power to the Garmin?
I had power to the Garmin and the outlet for my heated jacket, but no power to the rest of the bike. I had carefully lined up the stuff I was adding, but managed to screw it all down without the main positive lead in place.No power anywhere, or just no power to the Garmin?
Sounds like something I would have done. In daylight, evenI had power to the Garmin and the outlet for my heated jacket, but no power to the rest of the bike. I had carefully lined up the stuff I was adding, but managed to screw it all down without the main positive lead in place.
I need to quit doing this stuff in the dark. My eyes aren't what they were when I started working on bikes in the early '70s.
Besides the windshield height (which is being taken care of as this is being written), this is my next big complaint. The way the totally useless left pocket is so loosely attached to the bike means that it flexes a lot more than it should, and I believe this causes the left inside panel (the one over the battery) to not line up properly once it has been removed. It could be, too, that I have some wires in there behind it that might be causing or at least contributing to this problem, and I will investigate that. (I admit I do have a number of items over toward the battery, including my garage door opener, the control module for my Photon Blaster lights, the battery Tender pigtail, and a fair amount of wires that could probably be shortened quite a bit.)I had a some trouble getting the cover back over the battery. It wouldn't go down on one corner.
Why, from 40 to the legal speed limit, of course!!!The Montana will need a slight adjustment to make it better when the sun is behind me. The speedo and the GPS were dead on from 40 to ...shhhh...
