This past Saturday I decided to take a longer ride on my new CTX, wanting to get some miles on it for the 600 mile service. So, first thing I do is check the tire pressure. Sure enough both tires were low. Not to worry, I'll just get out my hand pump and give them a few pumps to bring the pressure up. Nope. I couldn't attach it to the valve stem because the wheels don't give much room at that point. Not to worry, I just fill the tires when I get gas. So off to the gas station. It was a struggle since the air hose was the kind that had to be pushed straight on. I couldn't bend the tip of the hose enough to get a tight fit on the valve stem. Rode to another gas station and they had the same type of air hose. So I went to the Honda dealer figuring they would have a hose fitting that would work. Got my air and went on my merry way.
But this leads me to ask those of you who have had your CTX for a while: What do you use to get air in the tires? The wheels on my NC700 allowed plenty of room for an air hose to fit. The CTX appears a little more cramped. Also, any suggestions on a reasonably priced small capacity air compressor? I only need one to inflate tires, no heavy duty work.
