1 - 10 of 10 Posts
Charlie Rogina (@menosabe) makes them to suit 30" or 32" inseams. If you're interested, I have a set of the 30", configured with mounting holes for lights. Comes with the pegs that Charlie recommended. I sold the CTX recently before I ever mounted the bars. Will sell for 50% of listing price
Sent from my SM-G955U using Tapatalk
David - if you wanna DIY it, check out the following thread. My setup is in post #23; a similar setup is in post #10.
Have about 20K miles on my setup to date. Most times I use them by having my heel on the rider’s foot peg and my inner foot resting on the “offset” bracket part and my center/outer toe area flat on the highway peg. Having a contact point both front and rear allows me to completely relax my leg muscles, as well as keeps my legs more inboard (more aerodynamic!). Can always just put ball of foot on highway peg (normal position), or lay legs over top of highway pegs for complete leg stretch.
I'm 6' with a 33" inseam I mounted a set to Charlie's brackets. But the pegs are too far forward to use effectively, plus the valve covers get in the way. I only use them to stretch my legs for a minute or so. I would not mount them again.
The pegs also extend past the forward engine bars. If the bike falls over, it pivots on the pegs rather than bars, causing damage to the mirror and saddlebag. [You know how I know.]
CTX 1300D
Can any one give me links for after market foot pegs? Or does anyone on here make them that I could buy from? I have a 2014 CTX and want some forward cruising pegs similar to the ones I have seen posted on here from years back. Thanks much! [email protected]
Hi, I ran into this same problem myself and found that simple passenger peg mounts work. The passenger mounts are curved and work around the cover on the bike; just tighten them down real good. Then I mounted Kuryahkn switchblade pegs to them. Here's a pic.
46126
CTX 1300D
here's a couple pics. You have to make a little bit of a cut-out on the cowling, but no one sees it.
46133
46134
These are the parts I used, all available on Amazon:
Only thing I would caution. I used the extenders to push them out a bit because the V-90 heads get HOT! You have to have them wide enough to avoid them when riding.
Good luck!
2014 CTX-1300
Good luck!
Where do these mount to exactly? Are there holes there that already line up with these passenger peg mounts? Thanks!
1 - 10 of 10 Posts
