i have read that this bike has trouble with the rear suspension /shocks. also, the transmission develops troubles and the wireing? any of this true? i am talking as a tendency /bad characteristic of the bike. not just from useage. what say y'all?
I bought mine used with grips already kuryakyn iso grips with end weights gone. Never experienced vibration. Already had ctx700 mirrors to increase mirrors view at a higher view point I'm used to being a tall rider seems right. I can see out original mirrors still but rarely look at them. Front shock has a little more feedback if you go over recommended inflation which helps tire wear, but doesn't bother me at 39lbs and extends next need to add airI feel like this bike is the swiss army knife of bikes. It can tour, cruise, and carve twisties unlike anything else I've ever ridden.
The vibration in the bars and the front suspension, and awful side mirrors are the only thing I can complain about, and those are all easily remedied.
If I were to upgrade, the Goldwing would be my first choice to try out. I've been driving and riding manual transmissions since I was 18. Time to let a computer do the shifting.The best bike I have ever owned! Think I am on #15 bike or so in my 57 years.
I would like to say (knock on wood) that I have not had 1 problem with my bike.
Yes I have modified it as Stan says to fit ME, other than the usual maintenance has not let me down after 6 1/2 years and 57,000 miles. The bike I would buy if the time comes to replace my CTX would probably be an Indian Challenger or Goldwing (the new gen) or maybe another CTX1300!
while a walking reverse sure would be nice, I look forward to the whole shifting gears thing...until traffic arrives, anyways.If I were to upgrade, the Goldwing would be my first choice to try out. I've been driving and riding manual transmissions since I was 18. Time to let a computer do the shifting.
the owners manual says 36 lbs in front 42 in the rear tire. sounds like the rear is too much to meI just recently went with 38 lbs in front and it seems to be working nicely. I'm not seeing that scalloping pattern showing up in the center.
I have been running 40 psi front and rear.the owners manual says 36 lbs in front 42 in the rear tire. sounds like the rear is too much to me
Rear is fine. It seems like the front doesn't get that scallop wear pattern with a little more pressure.the owners manual says 36 lbs in front 42 in the rear tire. sounds like the rear is too much to me
you dont find that a bit too rough riding? too stiff on the front end?I have been running 40 psi front and rear.
I found my front end a little stiff in the beginning before I increased the tire pressure. A bump or small dip like a below pavement man hole cover caused quite a shock in the grips. The handlebars were kind of bouncy on rough pavement like the shocks were too stiff.you dont find that a bit too rough riding? too stiff on the front end?
I have 56k miles, and the transmission is tight, I have no wiring issues,and the suspension is more a matter of personal choice and riding than actual failure.i have read that this bike has trouble with the rear suspension /shocks. also, the transmission develops troubles and the wireing? any of this true? i am talking as a tendency /bad characteristic of the bike. not just from useage. what say y'all?
