Today I installed the Kuryakyn mini boards. Total install was super easy and took about 20 minutes. The correct adapter is 8808. There are three possible positions. Initially I went with the center hole but that didn't leave enough room under the shifter for my fat foot. so...I moved them back to the front hole. Perfect. There are also multiple angle adjustments but mostly I just tried to get them flat. Resting your feet on a flat surface is surely more relaxing. And it is a lot easier to find the rest point when launching. I think these will be a good investment over the long term. However, I suspect they may scrape if you lean it over quite a bit. Haven't done that yet. :520:
