21 - 30 of 30 Posts
Rear trunk carrier base
I was installing this yesterday and the instructions say " Be sure that the rear carrier base moves right and left smoothly as shown" Can anyone help here... Are they saying don't tighten the bolts too tight to prevent the 1/2 movement and if so I don't understand why, anyone been at this confusing place.. :ty: thanks in advance
Trunk base
rear trunk base has a little side to side built into it
So does that mean I need to loosen off the bolts until it can move??
if you have all the washers in correct it should move when the bolts are tight
it doesn't flop around because the 2 robber bushing in the middle. just a little side to side
all bolts tight, should move
Thanks Gtmn appreciate the help I thought I installed them right but will re-check, appreciate your time....Jim :ty:
no problem at all
go to Hondas web sight
pull up ctx
pull up accessories
go to rear box mount and it will give a great pic of how they all go on it
just mounted mine last week and was a breeze
good luck
no problem at all
pull up ctx
pull up accessories
good luck
Mixed up the order of the plastic and rubber washers, working good now...thanks again Jim :smile:
21 - 30 of 30 Posts
