Probably not a good idea to drink beer while fiddling around with your new CTX. Tonight I decided to put the Battery Doc harness on the battery. I pulled the first piece of plastic that allows you access to the battery and then proceeded to simply unscrew the bolt on the positive terminal. I dropped the bolt and it vanished into plastic shroud land. %*$#@ So what the ****? I finessed the inner shroud off and then started to pull off the side shroud. Tabs, clips, rubbery thingies galore. Lots of pushing, pulling and bending. Finally, I pulled the side shroud off enough to see the bolt. Retrieved it, buttoned everything back up and then installed the Battery Doc harness. As I was putting the final piece of plastic back on I dropped one of the plastic pins. It vanished into the void of plastic shroud land. Screw it. The good news: the Battery doc works fine. Tomorrow I'll drop by a local shop and see if I can buy some plastic pins. FYI. The people who drew the figures in the manual were likely on some drugs. It is totally worthless. Next adventure: figure out how tap some power for my photon blaster led lights. Any suggestions?
