1 - 8 of 8 Posts
I had a guy slide onto the highway beside me today then pushed me into the lane to my left. Good thing that lane was free 🏍. Not the first time this happened. 😒
So I think a better / louder horn might be an advantage.
Has anyone used a car horn in place of the stock M/C horn?
Because the horn is hidden I was thinking it didn't need to be cosmetic, just functional.
comments?
thanks
Glen
The only thing I would worry about is the current draw. The horn switch and wiring might not be able to handle the higher amperage of a larger horn.
Use the horn wiring to trip a relay and run the power for the horn from the battery with an inline fuse for safety. Don't want to have a possible short on an unfused wire.
A pic of my Kawasaki Vulcanstein collecting dust. Two horns in the windshield, two more underneath. I definitely had to use a relay.
Vehicle Automotive lighting Hood Motor vehicle Automotive tire
I installed a DENALI SOUND BOMB air horn and love it. It's a little pricey but not too bad if ya want people to hear you. For a few bucks extra you can order their wire harness with a relay that's pretty much plug and play into the original horn wiring. So it works properly from the horn button. It's small, maybe the thickness of a bagel and square like sandwich bread. Check em out online. People will hear you.
Bagel, sandwich? You're making me hungry.
Thanks for the comments, yes, I can check current draw before installing. I looked at Denali and PIAA.
I was thinking a "too abrasive" horn would have a negative effect?
I will do some testing |:)
Glen
1 - 8 of 8 Posts
