1 - 9 of 9 Posts
Nice work on the machine and the pics. You're a braver [and probably better looking] man than me.
I don't attempt anything that would disable the motorcycle if I fail. This work looks like a prime candidate for that category. I learned this lesson from experience in other areas. Plus I have paid to replace both middle cowls over the course of years.
That was a lot of work to assemble those photos, thank you Glen! I did my air filter and suggest you allow lots of time and space for the project. I used a blanket and laid the part so I could find everything to reassemble. Every step in the manual refers to another for a “first remove this panel see section ...” it isn’t hard just be patient. Warning,( as was previously mentioned by Glen ) the front coloured panel that wraps up to the headlight has a clip that hooks into the headlight assembly. I broke the tab and glued it back with plastic epoxy by JB weld, seems to be holding ok. Good luck.
When I installed the McCruise system, everything has to come out. - even the air filter! I replaced mine with a new one even though I had another 8-10K miles left on the original one. I figured might as well since it was all open. I don't want to do it again..... took me way too long to take it all apart.
Nice Job!
I just replaced mine a couple weeks ago. All I have to say is: Really? That much work to replace an air cleaner? Apparently, some of the old Jaguar engineers found their way to Honda.
You should try replacing the air filter on a ST1300. It's basically the very same air box and filter but with a few important differences. On the ST you have to remove the upper gas tank (yeah, there is an upper and lower gas tank) to get to the top of the air box. On the CTX you just have to remove the top shelter and some electrical do dats stuck on top of it. On the ST the air filter just sits in the air box and is held down by the air box lid. On the CTX it is the same lid... as far as a million screws around the perimeter, but since there is also less space to fit the top of the air box in place without knocking the air filter out of place you have 2 screws to fasten the air filter to the lid to keep it in place. Some here have used the ST air filter (costs less usually) and drilled the 2 holes using the old filter as a guide and used slightly longer screws since most ST air filters have a thicker top plate. Otherwise it is the same filter and air box.
1 - 9 of 9 Posts
