1 - 4 of 4 Posts
I am trying to remove and repair saddlebag plastic skin (blue).
Can't seem to be able to remove it. One allen head bolt inside bag and that's it, but it will not come off.
Any help available on this?
Thx
:350x700px-LL-66dd6d
Come on guys! Someone has to know how to remove the side panel on the saddlebags.
guy
I just did . On the bottom there are two tabs that you need to slide out from black casing. I used a couple of dimes to keep the tabs from not sliding back in.
You just need to get something in between the inside of the painted cover to pry it off as there are about 6 or 7 strip of two sided tape holding the cover on. If you have the replacement you will see. Do not forget to put back the screw thing you took off. Sorry if directions are not great. On my tablet in bed.
It seems like your gonna break something but it does take a good bit of Steady force to pull it off.
Good luck
1 - 4 of 4 Posts
