I have done it...
:515:Twice no less!
the first time I was starting out from a light along side a Harley guy. We both told the other to go and I eventually decided to go, figuring he wanted to check the bike out. Not sure what I did as all of a sudden I heard a screech from front tire (with it partially turned ) and then the tilt to right started and went too far for me to stop it so I (and bike) did a semi slow drop to right side. Very embarrassed I slid my way out from under it and the friendly guy next to me quickly got off his to help me get it upright as check if I was OK. It was a bit more work than I expected to get it up from horizontal. My first thought was the ABS applied (in error) the front only brake, but I don't think I was moving fast enough (>6MPH) for it to even be in service. I can only assume I screwed up (brain fart) and hit the front brake vs clutch in error but really just don't know as I've never done that before. And this was only my 2'nd ride on the new bike.
The right side /engine bar COVER was barely scratched, the mirror cover popped off and was scratch pretty good, front exhaust chrome cover was a little scratched and deformed/shifted, and the rear muffler cover were scratched (both on bottom so not that that noticeable), and the front right lower corner of the bag painted portion was scratched pretty bad. I was able to buff out 90%+ of mirrors issues. I could not do much to the bag cover so initially did some pin striping to make it much less noticeable. A few days later I went to my dealer to check availability and pricing of some parts. I decided the mirror cover repairs done were good enough vs cost to replace. I could always change my mind later but I did a good job so I doubt it. I ordered the cosmetic "front portion" exhaust chrome cover and pre-painted saddle bag colored panel. (Dealer gave me a break on cost-due to the cause so both totaled ~ $200) The rear portion muffler cover is part of the muffler and can not be separated. And cost of the entire muffler is a bit too pricey to justify (at this time) for some minor barely visible (since on the bottom) scratches. Took a few weeks to get them ( that was a month plus ago). But I have yet to put them on.
Good thing too as a few weeks ago I was trying to turn around on a driveway with a very bad surface plus severe angled/bank. At one point I did not have enough control Too short on legs (and old)... as I was in neutral and moving using feet as best I could reach. But I did A TURN WITH TOO MUCH LEAN, HIT FRONT BRAKE (I'm guessing again) AND LOST IT AGAIN. :350x700px-LL-66dd6d.
This time I was able to stop it (BARELY) before a complete touch down, but the front muffler cover and bag cover did hit somewhat- due to the very irregular and severely banked terrain. I could barely keep it from resting completely and hoped a passing car might stop to assist. But 2 went by with a stop, and it was not a high traffic area. I was running out od strength. Some how I got my left leg around ( I must have let it gently rest but not sure) to use crunched legs and back to get it upright. As I got near vertical I realized a big problem... I had not thought to put kick stand down before getting set to raise and could easily lose it once up as I was REALLY
straining and barely able to do what I was doing. I must have had an adrenalin burst which enabled me to some how stretch my left arm to the stand while holding bike off the ground (somewhat) with back and legs. Once up and on stand I had to sit down and settle. I was quite exhausted, shaking ( muscle strains) , and of course upset with myself for letting bike and me to get into the situation. So now I have a bit of a phobia about will there be a 3 ( and hopefully final) time I do the same thing. As such, I may hold off the 2 new part replacements until end of the season lay up. I'm waiting for touch up paint availability to do some work on bag cover corner. Being the dark blue, the black below the paint doesn't' make it too noticeable ... BUT I CERTAINLY see it. And I removed the pin striping there as I wanted it on the upper horizontal ridge vs lower.
Point of all this sharing my story of embarrassment is confirm from personal experience (and TWICE) that the front drop protection with engine area covered bar works reasonably well. BUT we/it also needs something in rear area like done on Wings. One point drop support leads to a pivot point allowing the rear bike panel and muffler to hit, where 2 would keep it up... much better at least and pending terrain of course.
Maybe aftermarket will have something to help if Honda doesn't in future.
