OK, here's my list:
>garage door opener and button from my current bike. hidden under fairing except the button on/near the left grip control cluster somewhere.
>OEM tall windscreen... maybe
or
MRA X-creen Tour Bolt-On Variable Windscreen Spoiler Blade Windshield Extension - maybe
>Home built fused power panel with isolation relay - hidden under fairing
or Blue Sea Systems 5025 ST Blade Fuse Block with isolation relay
Stebel Nautilus airhorn (black) - hidden under fairing and connected to supplement factory horn, not to replace. I did this same setup on my last 3 bikes.
Grip Puppies - maybe, if the grips are skinny (skinny grips make my hands cramp)
>Throttle Rocker from my current bike - Thought I'd need cruise after my GW but found I do just fine with this.
Oh, wanted to ask how's your wrist
Dave???
RAM mount for my GPS - haven't decided where it would mount yet but that would dictate what RAM mount parts to get.
>Garmin GPS cradle and direct wire connection from my current bike
>Gerbing heated gloves variable controller and direct wire connection from my current bike
Knight Rider *Non-Sequential* LED Light Bar with Flashing Brake Alert - 4.7" 12 LED bar mounted just over license plate
I currently have the longer sequential 7.5" 21 LED bar mounted under my trunk mounting plate. The sequential (moving light) part is not really legal everywhere but I was told by no less than a dozen LEO (I asked) from all over where I ride (including other states) that no one would pull me over for just that.
>12v 15amp power port in saddle bag - on only when bike is on.
May have a second 15amp power port in other saddle bag that can be on all the time, or on it's own switch, powered directly from the battery for emergency use and change the switched power port to 10amp.
>LED driving lights - haven't decided which ones yet. To mount in same location as OEM driving lights.
>Kwik Tek Dry Pak Waterproof Duffel Bag (110 Liter) in leu of a trunk for LD camping trips.
>Oh, and of course a service manual. Gotta have that to do most of the above.
All electrical items will be powered from my fused power panel with isolation relay (turns it on when bike is on) except possibly one 12v power port. My home built power panel will have 6 fuses (or the Blue Sea also has 6) and I have 6 items here that need a fuse (other than any second always powered 12v port that would have its own inline fuse). I do all my own wiring and connectors. I use shrink tubing insulation where I can and liquid electrical tape (paint on) where I cannot. My wires follow OEM wire harness where possible.
